whatchel1 SatelliteGuys Master Original poster Sep 30, 2006 9,098 51 Great High Plains Dec 20, 2012 #1 I would like to know if a DP-34 switch work w/ a VIP 622?
primestar31 SatelliteGuys Master Lifetime Supporter Mar 15, 2005 14,830 17,451 Beta Omicron Delta III Dec 20, 2012 #2 Of course, that's what they were made for. I used one for years until I needed another sat, and then went to the Dpp44
M mattv SatelliteGuys Pro Pub Member / Supporter Lifetime Supporter Sep 14, 2011 150 14 n/a Dec 20, 2012 #3 yes it will work - but only if you run two lines to the receiver. the DP34 doesn't work with the DPP separator modules.
whatchel1 SatelliteGuys Master Original poster Sep 30, 2006 9,098 51 Great High Plains Dec 20, 2012 #4 mattv said: yes it will work - but only if you run two lines to the receiver. the DP34 doesn't work with the DPP separator modules. Click to expand... That is exactly what I needed to know. So if I want a single line I need a DPP switch?
TheKrell A mighty and noble race originating on Altair IV. Pub Member / Supporter Jan 4, 2007 39,057 47,068 Fairfax, VA Dec 20, 2012 #5 whatchel1 said: That is exactly what I needed to know. So if I want a single line I need a DPP switch? Click to expand... Correct, as in a DPP33.
