Will a HR24-500 Receiver work with a SWiM Dish? | SatelliteGuys.US
Mark Smith298
Chicago
I have a Dish with LNB SL3S4NR2-01, if I purchase the HR24-500 HD DVR, will that be compatible? I notice there is only 1 coax line running out of the dish but the receiver has 2. Do I need to purchase anything additional?
Also, if it works, what will the capability be of recording vs watching a different channel, etc? Thank you in advance for for all your help!!
Yes, that will work.
You have a total of 2 tuners on that unit.
You'll want to run the coax to the side that says Sat 1.
With that swm set up you'll need a Power Insertor as well ....
Is this recvr being added to a system or is that the only one on the set up ?
Directv to shift away from Satellite?
No signal Tuner 2 HR23 700
