Will Dish Activate | SatelliteGuys.US
Will Dish Activate
Bob55
44
4
Ohio
an old 381 receiver?
I purchased it new as a spare long ago. Never activated so it does not have a card. Lost signal yesterday and used it to confirm loss. The cable came out of the old style crimp connector at the lnb.
It took a software update from P429 to P469 and receives 110, 119 and 129 on a 1000.4 dish. I have no real use for it except to confirm as above and was wondering if it was worth passing it on.
I don't think they will, but a call to Dish or better, a PM to DIRT will settle it.
Posted Via The FREE SatelliteGuys Reader App using an iPhone.
An 811 is MPEG-2 for its HD. Dish has no MPEG-2 HD channels, now. So why?
It might work on WA for SD channels but even if allowed better to get more modern and a DVR, too.
The 811 came first then DISH rebadged it as a 381 and sold it for WA SD broadcasting with an ATSC tuner built in. I have two sitting idle but if they are no longer being activated they become a little more electronic scrap.
Thhe 811 should fall under the legacy reciever group as well. And I don't beleive are being activated either.
It took a software upgrade. So why does Dish bother with that since it can not be activated? Why not just totally disable the unit instead?
Bad wireless Joey install experience
Ending Missing
