will dish pro plus work | SatelliteGuys.US
rob1111
5
arkansas
Hi I have a dish model 3700 and have a dish pro plus antenna. Will this work together or will I have to get another antenna? Thanks for the help in advance!
Do you mean you have a Dish 500 satellite dish with a Dish Pro Plus Twin LNB mounted on the dish? In theory a 3700 will work with a Dish Pro Plus LNB but reality may be different. The power supply in a 3700 was not designed to run a DPP LNB and the electrical demand may exceed the capabilities of the 3700. The DPP should be used with a Dish Pro receiver and a LEGACY (3700) receiver as the second receiver on the system.
Two VIP 211's Question:
Using EHD on multiple receivers
