hi would like to know if shaw will come in in sd in playa del rey California. I had bell working here till jully 5th last year. thanks.
yes it will work fine. Both the SD & HD satellite reach into Mexico
also note, the new satellite (G1) will not reach below the northern US once it is launched and operational. However, the new sat is expected to have local channels. and instead of the 75 cm dish, you can also use two separate generic Ku band dishes with an external multiswitch.
No it has not, and the date for the now-postponed launch depends on which website you read or which person you talk to. But as far as LA goes, it's irrelevant because you won't get it when it does go up. And it's not an "HD satellite", per se. Current HD programming comes mostly from the existing satellite Anik F2, though Anik F1R also carries some HD. If they someday decide to move all the HD programming to the new Anik G1 satellite, then you will not receive any HD in LA, but I have seen no information that indicates that this is currently Shaw's intent.has the new hd sat been launched?
I'm not sure how to answer your question. All I can state is that I read this forum and another similar forum from Canada on a regular basis and I have been a Shaw subscriber for several years with full access to their website; I have not seen any information that has stated that the US will go dark in the forseeable future. If anyone has reliable information to the contrary, please share it.also how much longer can I wait to get shaw and still get it to work in los angeles?
"Just be aware that the LNB (quad or xKu) must match the dish".
I swapped out a xKu for the old LNB, and the dish didn't matter.
That's correct. You can put either an old 75e LNB or an xKu 75e LNB on a 75e dish and it will work fine. But it won't receive any signal from Anik G1 unless you live in the northern part of the US.I swapped out a xKu for the old LNB, and the dish didn't matter.
That's correct also.the LNB for 60 cm dish won't work on 75 cm and vice versa
Yes, any new equipment is likely to come with the nex xKu lnb, and that is fine. When Anik G1 goes up, most of the US will still continue to receive the old satellites with the xKU but not the new satellite. What is a waste of money is for an existing customer with the older quad LNB to purchase a new xKu LNB, remove his older LNB from his dish and install the newer one. It's not going to add any new channels to his reception because he won't be able to see the new satellite, even though he has the newer LNB.you said its a waste of money for Americans to get an xku lnb but isn't that what comes on the 75cm dish
Okay sorry I thought the OP didn't have Shaw so he would be new and would get all new equipment, I didn't know he already had a Shaw dish and wanted to buy a different lnb.Yes, any new equipment is likely to come with the nex xKu lnb, and that is fine. When Anik G1 goes up, most of the US will still continue to receive the old satellites with the xKU but not the new satellite. What is a waste of money is for an existing customer with the older quad LNB to purchase a new xKu LNB, remove his older LNB from his dish and install the newer one. It's not going to add any new channels to his reception because he won't be able to see the new satellite, even though he has the newer LNB.
Limited time offer
