I was a tech for 12 years..Our shop( Dish fulfillment contractor) had a rule about rental properties. No written permission to install. No install. Period.
I made use of tax assessor's websites. I would compare the name on the account with the name of the listed owner. If they did not match, I would ask the custy if they owned or rented the home.There's almost no way to know if someone truly rents or own their home. I got written permission for the first install but not for work since then. This will be a on going problem. Didn't this guy look at his rental property while it was being rented out?
Sent from my iPhone 5 using SatelliteGuys Reader App!
Boy, that guy sure pays attention to his rental property, eh? The dishes were there for four years and he didn't know?
Not here in this state. And Dish had and probably still has a policy where land owner permission is required before work can start.Nope, no tech is going to care, thats the LLs problem. technically the tenants problem, the tennant signs the directv work order assuming liability for any and all damage done to a structure that could be defined as a dish being permenantly attached to the structure, or the drilling of holes to run cabling. The handheld electronically signs all this now. So once the CM signs, its their problem. Not DTVs not the Tech that did the install.
In many cases, the owners live elsewhere or they own several rental properties.
Regardless of where they live they should know what's going on at their houses.
In a perfect world, you would be correct.
Many property owners with multiple properties use management companies.
That question would catch the custy off guard. If they had to think about the answer and then stated they owned the house I would ask "who is( name on tax records)"?
At that point 99 times of 100 I would get an honest answer.
Pretty easy. Most areas mkae use of the county website, as to where the property assessors info is located.That is a good idea. Never knew they existed.
Limited time offer
