Will this dish work for FTA? | SatelliteGuys.US
It will work, but is a little on the small side. You will need to get a different linear LNBF and fashion a way to mount in the exact same spot as the old one.
It will be enough to get your feet wet if you are handy with making some modifications.
No the modem is worthless, without a subscription.
PC Not Recognizing Prof 8000 DVB-S/S2
Some feeds has number of Degrees mentioned why is that ?
