Will this dish work on Shaw? | SatelliteGuys.US
If that is a pic of the actual item that is the old "beer can" setup for Shaw. It would work but you need a switch to combine the 2 LNB's (I dont see it in the specs or pictured). The switch is an older style with 2 inputs and 2 outputs that works with a stacked system. Here is an example
How many receivers are you hooking up?
Even with the high shipping charge from CA to US, it looks like it will be cheaper to get everything from kusat rather than to purchase the dish/lnb, switch and receiver from three different places.
yep. Usually it is cheaper and honestly the non stacked system (quad LNB) that is in the new systems is easier to use than that stacked system
I tried to Google up the specs on that LNB using the part number, with no success. Is it likely that the configuration shown in the ad is set up for a 4-degree satellite spacing? The OP would be foolish to invest in this hardware unless he's assured it's gonna pick up both Shaw satellites........?
