will this work? | SatelliteGuys.US
will this work?
nanaberry
60
Galion, Ohio
I already have Dish service with a dish 1000 and I have a switch box it has 4 imputs only 3 are being used. To get Sky Angel we have to put a second dish on the other side of our house. Np problem. My son has a SuperDish HDTV dish he no longer uses he said I could have it...will it work to receive Sky Angel and can I run the line from the dish getting Sky Angel to the 4th imput on the switch? Thanks for any imput.
its overkill but it will work :)
The SD is a pretty big dish (36x20) whereas a simple Dish300 is 18" and a DIsh500 is 20"
As far as cost goes it's easier to call Dish and ask for the upgrade. You're going to have to purchase a new LNBF which will probably cost more than it would to have Dish do it for you.
Why do you choose skyangel over FTA?
Satellite vs. FTA/Cable GTN Programming
