Willow Cricket Moved? | SatelliteGuys.US
ilfoman
105
North
Came home today and channel 582 is no longer available on 61.5. Did it move to 118.7 ? If so, how do I get it back. i have a dish pointed at 119. Will this work with a new LnbF and can I connect it to EARC DPP set-up? Thanks guys.
You can view it for now on channel 6125, but the channel will be removed from 61.5 completely in time. If you want to PM your phone number or account number, I can set up the 118.7 install for you.
You can not pick up 118.7 with a regular LNB. 118.7 is a FSS satellite, and needs a specific LNB
Thanks for the advice Matt. I found a FSS LNBF and attached it to a 24" dish and it works great on my old 4900 receiver. So problem solved.
sling adapter
Any better way to browse movied on VOD?
