Windows MCE Guide Data | SatelliteGuys.US
SpiffWilkie
557
Memphis, TN
I have a Hava device that my FTA receiver is hooked up to. That Hava, in turn, is hooked up to my PC and I can control it (and the receiver) through Vista Media Center. The problem is that I can only get guide data through one source in MCE. Does anyone know of a 3rd party app that will allow me to customize the guide (sort of like a TitanTV sort of thing) or if it's possible to edit the MCE channel/guide database?
Thanks,
Steve
Search for 'wmcGuideServiceProxy' and 'Bladerunner Pro' and you'll find more information about getting xmltv format into MCE. You should be able to find some tools to get xmltv data out of titantv.
N3 is working!
which part of the country has the best fta signals
