hdtv_md Member Original poster Jan 15, 2008 7 0 Feb 1, 2008 #1 Argh! The Winegard 2076 foot plate is way too big for the Commdeck. So-o annoying! Can I mount the Winegard dish on some cheap mount that will fit? I believe the pipe size is a standard 1.66 inches. Thanks!
D dishrich SatelliteGuys Pro Sep 8, 2003 3,414 555 Springfield, IL Feb 2, 2008 #2 Yep, just use one of the standard J pipes that come with any D* or E* round dishes, or even the oval 18x20 D* dishes. I'm using one to support one of these dishes myself.
