Winegard single lnb & Direct dvr | SatelliteGuys.US
tnjpa
I have a winegard single lnb dish on a camper I just purchased. I tried hooking up my Direct dvr from my house and got signal on sat 119 @ 75% but the screen just kept saying getting info from satellite and never did anything. Am I totally not doing something right here? Is this even possible to do?
I would try to locate the 101 instead of the 119 and see if that helps it work better.
Depending what rec. your trying to use, with the single LNB your programming will be limited with just a single lnb dish.
Jimbo
Biography HD showing first HD program.
moving a subscribed receiver to Canada
