wing dish for EA dish? | SatelliteGuys.US
all4jo
398
12
Haiti and lexington ky
Hey guys i have a EA dish , but i would like a dish also pointed at 119 for All american direct Locals. how can i make that possible? right now all the lines from EA dish go directly to receivers.
Thanks.
How about if i want 129 with EA, aim a 300 at 129 and connect to 1000.4 input? I lose 61.5 alot
Yes that will work as well.But if your losing 61.5 you may want to get the dish fine tuned.
Have you tried realigning your dish to get a stronger signal on 61.5? Are all your satellites EA or combo EA/WA? You could use a wing dish to get the 129 satellite and as stated above run the coax to the 4th port on the LNB. After run a check switch to add the 129 to your receivers.
EA dish with 110 wing on a hybrid combination of two patio mounts.
Downgrading while under contract
D1000.2 Technical Questions
