winguard ds 2076 | SatelliteGuys.US
winguard ds 2076
jerryd
110
Central Wisconsin
Can anyone tell me if the Lnbs that came with the 30" wineguard DS 2076 will work with dish network on 110 and 119. I want to replace my existing smaller dish 500 with the larger dish to overcome outages with rainstorms and snow. I can't seem to obtain the signal with this dish, If the lnb that came with the dish needs to be replaced with the lnbs from my dish 500 is there a special mounting bracket available so that the lnb can be mounted on this dish. I have a dish 921 receiver.
Any advice would be greatly appreciated
JerryD
Unless I'm mistaken, I believe you would need two of these - one each for 110 and 119 as a D500 is designed to pick up two satellites and the 2076 is designed to pick up one.
The 2076 is for DirecTV or FTA apps I believe, which uses what Dish would consider to be a legacy LNB. The 2077 is designed for use with Dish pro LNBs. See http://www.daveswebshop.com/76dss_dish.shtml for more info.
Look at me, I have been Permanatly Banished from Satguys!
DVR and Dish Network
