When our system was installed, the installer used the existing coax network in our house. There are 4 wires coming from an SW44 switch running to 4 different rooms. As of now only 3 receiver are being used. However, one is a dual tuner PVR and I would like to re-route one of the lines.
This is outside the house. Pretty typical.
Here are the wires coming in from the SW44 and being fed into the house's existing coax network.
You can't really see it, but each wire is labeled 1-4.
Now for the questions. Pretty stupid one first, but I'm assuming the numbers on the wires correspond to the output number on the SW44. Correct?
Also, once I figure out which wire feeds to the outlet that is no longer being used, is it alright to snip it, and re-route it into the second tuner of my PVR?
Thanks for the help!
