wireless bbdeca and aircard | SatelliteGuys.US
memory
186
working usually
I asked this in the installer forum but I am gonna ask here also can a wireless bbdeca connect to a aircard that plugs into the usb port on a computer
YES!!! The question I am asking is can you use a directv wireless BBDECA to connect to a aircard you have for your pc for your internet connection for your DL's for movies and stuff
yes and no, it has nothing to do with directv, what you want to do is rebounce the internet off your aircard into a router, and connect the bbdeca to that, you cant use your pc as a host.
aslo, check with your aircard provider, this maybe against their tos or aup, and watch your bandwidth limits, ondemand is going to destroy them lol. An aircard is supposed to be used to allow internet access to a pc, not power a satellite internet connection. It will work but not as well as you are hoping it will, and your ping is going to be horrible.
SL3PIG-WNC HD Compatability
free family hardware... Directv compatible
