Can someone give me a name and model for a wireless ethernet adapter needed for the directv video on demand service.
paulyme
paulyme
I have a Linksys wireless-G router and use the Linksys wireless game adapter WGA54G
I'm using a Linksys WGA600N Wireless Gaming Adapter on my HR20 receiver to get VOD and PPV. Works great...
I found the WGA54G on Ebay nib for 49.95. Now if I could only get it to work I would be a happy camper. I hate wireless networking stuff.Are these relatively cheap adapters? I mean I can't spend like $75+ on this, especially since I don't order much VOD stuff.
Wireless router is a Netgear 54G. Security is setup as WAP & WAP2 so it will recognize both TKIP and AES encryption, DHCP is enabled. When setting up the Linksys you only get options to set the SSID, the security scheme and encryption, and DHCP or Static IP. I set the adapter to WAP with TKIP encryption and DHCP. It sees the network, all 3 light are lit, but it will not get an address from the router, either from my PC or the HR21. I have tried shutting all off and turning back on. I have tried all the security and encyiption schemes. I even tried setting a static address for the Lynksys, 192.168.1.250. All the same results. 3 lights but no connection. My laptop works just fine with the same settings. Did I miss something?Can you describe the problem/ do the fromt lights go on/
Only settings in the adapter setup I have found are SSID, Security (WAP, WEP, etc), Encryption (TKIP, AES), and DHCP or Assigned IP. I have set these to match the router and the router for some reason does not assign an IP address to the adapter.Is there any setup screen that asks if you want the adapter to pull the MAC address (or MAC ID) from the device? If there is say yes.
My WGA54G works GREAT! Just make sure you set the IP to be STATIC. This implies you need to set the DNS, subnet, and gateway. I've had intermittent problems with the dynamic IP settings.
so, on your computer that is connected to the HUB or wireless hub go to START-->cmd enter, then type ipconfig/all then enter at the prompt
copy all the DNS, subnet, and gateway off of that. Choose an IP which does not conflict with any others on your network. The Linksys software for this Wireless Game Adaptor (WGA54G) is easy to use.
One trick is that you have to have the WGA54G plugged into the router when programming it. Also, you have to have the same security settings on the game adaptor as you do on the router.
Now you see why a lot of us recommend using powerline networking.![]()
Limited time offer
