Wireless for VOD Advice | SatelliteGuys.US
satjay
12,720
898
Michigan
Will a NETGEAR wall plugged Etherent bridge work for the HDDVR for VOD...I only ask because it is a bit cheaper then the "powerline" version. If it will, it should be plug and play also?? I want to purchase one of them today
Or a second question will either work!
thanks for any assistance
The Wall Plugged Ethernet Bridge is a powerline device. If you decide to use this method to connect your receiver to your router, remember that you need two othese powerline to Ethernet bridges (one connected to the receiver's Ethernet port and the other connected to an Ethernet port on your router).
NHL Center Ice Schedule
College football in HD on 620-1??
