I tried inserting a wireless usb adapter into the port on my 722 but nothing happens. What do I have to do to activate it.
Brian9811 said:I tried inserting a wireless usb adapter into the port on my 722 but nothing happens. What do I have to do to activate it.
The Netgear 802.11N model WNDA -3100v2 WiFi Broadband Connector is the Wifi device we officially support, so if it's a different adapter, it's probably not going to work. You can order the official one from DISH for $25
Will this work on a 211K?
Is the official Wifi device covered under DHPP?
stardust3 said:I don't believe that's going to work. You're going to have a sling link adapter. Amazon.com: Sling Media SlingLink Ethernet Connection Bridge: Electronics
I may not post a lot but when I do I make every effort to be sure I know what I am talking about. When I stated that the usb wifi adapter that is supported by dish and available on their web site, is the one that works that shouldhave been a clue that it works. I also pointed out that it is possible to obtain the same adapter elsewhere for less if one is so inclined.
Ross
Sent from my DROIDX using SatelliteGuys
Limited time offer
