Wireless Sirius car radio | SatelliteGuys.US
how do u go about installing that? not sure if i can get to my car stereo
Depending on your brand of car, it is just a matter of pulling the factory radio out just enough to get to the back where the factory antenna plugs into the radio. The Ford's I have used this product on required a small tool to release the clips holding in the factory radio. Any Best Buy, Circuit City, Ford house or car audio store has one of these tools. After you see it, you will say, " I could have made that!"
See if they make an AUX input adapter for your factory radio. That would give you the best sound possible for a factory unit.
XM to Sirrus...made the change...
sound quality xm vs sirius
