Wiring for ribbon cable | SatelliteGuys.US
Brabo
18
Columbus, Ohio
Someone gave me an analog receiver but the ribbon cable had been cut and removed from it. There is a red wire, white wire, and a group of smaller wires (green, brown, and orange) wrapped together with an unshielded wire in blue paper like casing. I also have the actuator but don't know where to hook everything to on the reciever. Does anyone know where they should all go? Thanks
Should be a Red a White and a Black same size these are for your servo motor for H/V then there will be two same size wires red and white bundled with the smaller wires. The Red and White wires go to your actuator and wire to the motor... the smaller wires are for the sensor in the actuator. If your receiver has the dish mover built in these should hook up, you will have to see how they hook up to the actuator and wire to the receiver the same way.
