Wiring issue for VIP 612 HD picture in an adjacent room | SatelliteGuys.US
bjm1
Ca
I just had a VIP 612 installed in a family room. I am able to get the same picture on TV #2 in an adjacent room through a coaxial cable - but the picture quality is non-HD. I am unable to run HDMI cable from TV #1 to TV #2 to get an HD picture on both due to lack of a crawl space/attic to pull the wire. Is there a way to convert the signal from the coaxial cable coming to TV #2 to HD quality?
The TV2 output on the 612 only outputs NTSC (SD.) The only way you are going to get HD to that TV is by running an HDMI run or a component run to it from the TV1 output, or get another receiver. You can use CAT5 Ethernet to make things easier and keep signal integrity over longer distance.
SEC FOOTBALL ON PEACHTREE TV THIS FALL
Traverse City, MI Moving to Eastern Arc
