Wiring Question | SatelliteGuys.US
Wiring Question
jcastera
3
I am receiving DirecTV on 101 (SD) in the Caribbean with a 1.80m Dish, and dual LNB. Currently, I have a setup with a DVR, and 2 additional receivers, making good use of my 2x4 switch. Is there anyway I can add another receiver ? I've bought a 5x8 Switch (Aspen S4180GX), but I'm not sure of the right way (if right way there is) to hook it up. Suggestions welcome...
It sounds like you need a 3 X 8 switch... if you have a dual LNB and are currently running into a 3X4 switch, then this would be a simple switch out... do a search for them on the internet... I have several 3X8's in my inventory...
You're saying I can't used what I have ? Will look one up. I' will PM you if needed.
Will the HR20 & R15 still work with Service on "Vacation Hold"?
ESPN Gameplan and Ordering
