Wiring Solutions from Signal Connect | SatelliteGuys.US
Whether you’re building a home or a commercial property, you’ll need at least one type of wiring solution, maybe more. For example, there’s electrical wiring, network wiring, radio frequency installations, and low-voltage wiring. You might not understand the complexities between these different wiring installations, but Signal Connect does. Our team of experts has planned and developed a huge variety of wiring solutions for residential and commercial spaces across the country. We’d love to add your wiring installation to our long list of success stories. Remember, when we work together, everyone wins!
Introducing the Enterprise Team​
We’re so committed to commercial installations that we’ve put together a dedicated team to head up these jobs. Our Enterprise team has expert-level knowledge in every type of wiring solution used in commercial properties. These are the people who homeowners and business executives turn to when they need a wiring solution, large or small. Everyone we’ve worked with has benefitted from our team’s high-level wiring expertise.
When it comes to wiring solutions, we’ve done it all. For example, we’ve delivered DIRECTV to yachts, trawler fleets, RVs, and big rigs. We’ve also brought this satellite TV service to hundreds of homes and multi-level businesses. Cell phone signal boosters are another example of our handiwork. We’ve made it possible for people to boost calls in everything from the smallest apartments to large commercial warehouse spaces. The takeaway here is very straightforward: our team can handle any wiring solution you need no matter how complex.
Are you wondering what you can expect when you work with our team? Well, our specialty is signal wiring. We work directly with your electrical contractors to make sure your wiring installation is done correctly and on time. Here are the three biggest ways that our team helps your contractors:
  1. Prepare a “system design,” which is a diagram of all of the wiring and equipment that will be used in the installation.
  2. Our team creates a highly-detailed floor plan analysis based on your facility’s blueprint. This shows the installer what goes where.
  3. Provide ongoing service throughout the course of the installation. If you contractors have questions or run into challenges, all they have to do is call our experts for advice and guidance.
There are two great reasons why we take this approach. First, this high level of pre-planning helps us make sure you get the equipment you need so your wiring solution operates at peak capacity. We don’t believe in recommending or selling you extra equipment that your installation doesn’t need. The reason we put so much into our planning is because it’s how we can be sure your wiring installation gets done correctly and on time.
Here are the different wiring solutions that everyone at Signal Connect can help you with:
Electrical Wiring​
This type of wiring solution is used in a huge variety of electrical installations. Basically, anything that uses cables, switches, distribution boards, outlets, and light fixtures is considered electrical wiring. This type of wiring is common in both homes and businesses. When installed in commercial properties, these solutions tend to be large and complex. While some of these installations are simple, most of them are not. It’s great for your contractors to have Signal Connect as their go-to source when tackling those tough electrical wiring installations.
Network Wiring​
Network wiring refers to all installations that use networking cables and hardware that connects one device to another. This equipment is used to network two or more computers to share printers, scanners, etc. These installations depend on a variety of cables such as fiber optic and twisted pair cables. These are just some of the things that you will need in order to have a successful installation. But where do you get them?
Solid Signal, our retail electronic equipment division, is the largest online source for cables. We can get you what your installation needs in any custom length and configuration. We also carry a huge selection of all the necessary equipment to make your installation complete. This is the reason that Solid Signal is the No. 1 online source for all your wiring solution needs. And, because Solid Signal and Signal Connect are part of the same company, it’s nothing for your knowledgeable rep to quickly and accurately configure your system design.
Believe it or not, there’s something even more important than the cables and equipment we carry. It’s our experience at delivering network wiring solutions to residential and commercial developments. Each member of the Signal Connect crew is an expert in providing network wiring to facilities of all sizes and types. Whether it’s a high rise or a boat, home, or RV, if it needs networking, we’ll make it happen. It’s as simple as that.
Radio Frequency (RF) Wiring​
There are two aspects to RF distribution. First, there’s the science. RF involves with the oscillation rate of an alternating electric current or voltage – or a magnetic, electric, or electromagnetic field – in the 20 kHz-300 GHz frequency range. These are the frequencies where energy from an oscillating current radiates off a conductor into space, such as radio waves. In most cases, RF wiring means some type of coaxial cable, but it can also be hardline or any other wiring where signal is carried over a physical medium.
DIRECTV and cell phone boosters are just two examples of RF wiring. Our first-rate team is the unparalleled expert in both of these services because it’s what we do every day. When you need either of these things (or any other type of RF wiring), you should turn to the high-level RF specialists that design and plan these systems from coast to coast. We possess genius-level knowledge and expert experience in these wiring installations.
And just so you know, you get our amazing, top-grade service after your wiring installation is done.
You might need a little more help later on down the road. For example, you might need changes made to your DIRECTV account, or you might need to add more antennas to the distributed antenna system (DAS) as your business expands. In most cases, you just have a question and need an answer from someone you can trust. Whatever you need, Signal Connect assigns an account management representative to you. This is the person you call whenever you need anything. You know what’s the best part? We provide these services to you for free.
Low-Voltage Wiring​
What is low voltage? Well, technically speaking, all AC wiring is low voltage. When we talk about low-voltage wiring, we mean special purpose wiring that’s not part of the network, electrical, or RF distribution. (These are in the 50-1,000 Volt AC/120-1,500 DC range.) These installations are specifically designed to send a small amount of voltage to a specific device for a specific purpose. Good examples of these purposes are opening doors, turning on lights, and watering lawns.
Signal Connect is the absolute best choice for providing low-voltage solutions for commercial properties and governmental facilities. Our team of experts will handle any type of low-voltage wiring installation that your facility needs. Seriously. No job is too big or complex for our talented in-house wiring geniuses to handle. If you’re home or business needs of smaller wiring solutions, our team will obviously its vast knowledge and skills to help with those too.
Wiring Solutions from Signal Connect​
As you can see, there are different types of wiring installations. Each one has its own unique demands, and Signal Connect delivers the solutions. There is no one better to handle these wiring solutions than we do. Our group will deliver the best wiring installation from beginning to end. By now, you probably have some questions about our process. The quickest and easiest way to get the answers you need is to call us at 866-726-4182. You can also fill out the form below and send it our way. Someone from Signal Connect will reply in one business day.
The post Wiring Solutions from Signal Connect appeared first on The Solid Signal Blog.
Continue reading...
