With a Gene HD-DVR, can you do this? | SatelliteGuys.US
mkerdman
90
3
With a Gene HD-DVR, can you -
1. Start a recording that you join In Progress (like a football game by example)
2. Then Pause that Recording,
3. Tune to another Tuner & Channel and Watch TV,
4. Then Return to Original Tuner/Recording which is still Paused where you left it?
No, I'm fairly certain not. You could accomplish this with DoublePlay, but you wouldn't need to start recording in that case either.
DoublePlay allows you to "actively watch" two different tuners. Watching one show, say "Football Game #1." You hit pause, then hit the down arrow and now you're on the second tuner, say "Football Game #2." Pause and hit the down arrow and you're back to where you left off on Football Game #1. This functionality is critical for me on Saturdays when my two teams are playing at the same time. :)
That is EXACTLY what I wanted.
Thanks!
Reactions: TermiNader
while you already have a satsifactory answer, for those who may be less prepared to start something like that this scenario does still work.
after you have started the recording, if you go into your recording list and start the program from there INSTEAD of the live feed, if you double tap exit to leave the recording, you will be given the option to continue your recording from where you left off when you go back into the recording list. so essentially so long as you have it recording and dont go through the guide this works.
Upgrade to 4K Question
RC72 remote disassembly
