Won't record when powered off? | SatelliteGuys.US
mfrodsha
46
I used to be able to set a timer that would record when powered off. For some reason, however, I can't record TNT HD programs when the unit is powered off. Anyone else seeing this problem?
Although I haven't tried TNTHD, I've had timers record successfully in both HD and SD, with the 921 in standby.
Try unplugging your 921 for about ten minutes (to allow all the capacitors to discharge and all the magic bits to reset). Then, plug it in, and DON'T TOUCH IT for about ten minutes. That worked for me when I had problems once.
Actually that worked.
I simply reset NMV and factory defaults and reset all over again. Now everything works like a 'charm'.
DP44 Switch ?
Just received my 811 replacement!
