lime4x4 said:...but the fourth slot doesn't show a sat just says connected..
lime4x4 said:yes i tried watching cbs-hd which doesn't show up not even in the guide
Good point, Smith, P.Smith said:Why you all ppl waiting for the DP44 ? You could use NOW Spaun DMK55x2, at least model 5582 included in newest FW of DP receivers (111,311,510,811 for sure ). You could connect one OTA and up to 4 DishPro dishes and have up to 8 receives. http://www.spaun.com/dmk5582f.htm
mikhigor said:Good point, Smith, P.
I've checked Spaun products and the DMK5582F seems to be a perfect fit.
I plan to replace my two DP34 with it shortly.
Do you know, whether it can support legacy receivers without DP adapters as the DP+44 does?
lime4x4 said:That would still be cheaper then buying the "aftermarket" setup..And i honestly due beleive that dish will help out there cust who require a 4 sat solution.
Limited time offer
