Would this work? Up to 8 Satellites on one "Network"? | SatelliteGuys.US
aasimbeck
29
Pennsylvania
Simply a concept. I have no idea if this would work or not, i just figured i would draw something up in photoshop real quick. Additional SW21's or DP21's would be used for Dual Tuner receivers, correct?
Would a DP21 be preferred to use here over a SW21? I mean, if the concept would even work that is.
I know that Dish Receivers only have slots for up to 5 Satellite Dishes, I wouldn't expect it could go on beyond that, But I don't know. However, couldn't this concept still work with FTA Receivers, etc.
Can the ViP's even see that many satellites? I mean the chip and memory and capacity of the table to handle many channels that may not allow for up to 8 sats. In other words, the killer may not be the fun photo-shop. It may be dead in the water even before you dreamed up the fantasy install. And no, I do not believe that install will work as you intend. Funny, though :).
Downloads
WD My Book USB HDD help needed
