Did I read somewhere that the editor for the X2 does not load or work with windows 7? Or was that a nightmare I had recently?
RT
RT
Yes, I got a few DLL errors when I installed it on Win 7 also. When the receiver gets delivered in about an hour from now or so, I will get the chance to see what happens.I loaded it on W7 yesterday and got errors when I did. I didn't try to use it, just uninstalled it, rebooted into Win XP and used it there. That thing is buggy though as I had it crash twice loosing what I had done both times.
Agreed. I really like the editor for the openbox at this time. It works well and does the job. Maybe as time goes by, the one for the X2 will improve. I will try it on XP and see what happens there.I recalled when the very first editor for the Openbox came out. It tooked weeks/ months to everyone to get familiarized. As time goes on it was identified some bugs such as the missing of H264/ AC3 / AAC which were later added. Now that everyone get to use it is a more friendly user. So , take your time , play a bit, there is always something new to learn. It tooked me a while a yes several crash but I find my way around!
be aware there were 3 different versions of the editor,you have to match the editor to the firmware.Yes, I got a few DLL errors when I installed it on Win 7 also. When the receiver gets delivered in about an hour from now or so, I will get the chance to see what happens.
RT
And the file you left here did load to win 7 w/o any errors. But the program didn't work. I have sw ver Sept. 17, 2013. Attempt to connect with rs232 error to a time out. Then you have to pull the plug. Maybe some day.......There is an August 15th channel editor that was released to work with Win7/8. I used a null cable and the EZM to load back my edited database to the X2. As mentioned I couldn't do it using the USB.
RT
Oh, I am not going to stop trying to get the editor to work. You need one of those to "fix" things in your box that you can not do without one......Its easy to drop and maybe some day.
The X2 editor is running fine. Sometimes you need to try several times to get the file to load without getting the time out error....... I found out that if you unplug the video cable (HDMI) from the box it runs faster and pass thru without the timeout error.
One of the big problems with these and other receivers and devices from China is the manual. Written by some one in China that know "some" English. Their translations end up, at times, being impossible to understand. A good manual needs more information than a statement of "Make the unit work."
RT
I think your "P" numbers are the storage numbers in your V-Box, correct? If so, then in my setup, they represent various satellites scattered all over the arc. So when I set up my X2 using X2 position number 1 it was G-Box number 1 but satellite 135. Next was X2 position number 2 and G-Box number 2 but satellite 103 and so on. That is why my satellites are in a mixed up list when I press the sat button on the remote. I NEED an editor I can get to work to fix this problem.I just had a brain fart on this Diseq1.2 problem. When you guys say you start with P1 then go to P2 ect, are you starting with 139W as P1 or do you start from the East end?
Here is one called Set Edit 100 from Germany that I bought for the OpenBox S-9 and also used it on the Manhattan. It costs about $30 for the registered version, but there is a free trial download that is limited to about 10 channel edits to test on your box. It seems to work on most ALI chipsets, someone with a X2 might give it a try.
http://www.setedit.de/startup_d.html
Limited time offer
