OTHER - X2 M1 HD - Polarity Voltage Problem on Ku | SatelliteGuys.US
OTHER X2 M1 HD - Polarity Voltage Problem on Ku
pacificrim
1,199
1,117
West Coast Canada
I'm about 1 hour into unpacking and testing a X2 M1 HD and the Cband side is great, but on Ku I'm getting voltage instability. The vertical voltage is in the neighborhood of 15.3v as measured from my AI S2 meter. The ASC1 does not know what to do with it, bouncing between H and V, but mostly H signal. Straight to the LNB just gives me Horizontal. I guess I have to send it back...Any thoughts. I have updated the firmware with no difference.
Solved - more or less
I stuck a 4way power passing splitter in between the X2 and the ASC1 and it went to 14.3 volts in Ku, and C is still a strong 13.8 on Vertical.
I am impressed that it is getting the Ozarks on 99. Its been a long time since I saw that mux.
Not sure what X2's problem is but I had the same issue with the X2 Premium Mini. They refunded the money and told me not to bother returning it.
OTHER DiSEqC Switch question
