OTHER - X2 Premium IV STB/receiver | SatelliteGuys.US
OTHER X2 Premium IV STB/receiver
lawdog71
74
51
utah
Anyone have one of these boxes? I am trying to edit channel names but get an "Out of Range". How do you edit channel names?
~scott
I've got an X² premium mini. I edit channels through the setup menu
TV Channel Editor with the remote.
~scott
I've never worked with one of those STBs, but if it's like most of them "out of range" is a USALS error report. When you want to work with a channel, transponder or satellite the STB wants to move the dish to that location first. If the satellite entry is not proper or too close to the horizon for USALS calculation you will get that error. DiSEqC 1.2 can control a wider range if you find USALS won't reach that far.
Reactions: FTA4PA and c-spand
Thanks....figured it out. Had to change that particular bird to non-motor than was able to edit channel names. Thanks.
Reactions: FTA4PA
