I get this on mine too... Sort off ... I just thought It was my FW.... EA vs EC
What I get on analogs It will channel from 1 to 3 to 5 to 7 ect...skipping even tp's maybe ??? If I manually enter 2, 4, 6, then it will proced to skip odds.... Makes it hard to search for ITC FP stuff!!!! It will do this on digitals too.. Notice It most on 900 dmx stuff, skips entire blocks of channels...
If any body has Any Idea's I'm all ears....
gardo403 said:thanks for the intel.... I'll have a look a at the "change dish settings menu" first...
I'm running a lnbf so than it really doesnt matter!! LOL
Mine will select 210 from 209 or 211 sounds like you have a corrupted map table.
gardo403 said:If you look in the first picture and at the bottom of the screen that was where the problem lied... alt channel tuning is the one that is easy on servo motors!
I don't remember doing that???? OPPPS!!!
Limited time offer
