XBox 360 Add-on On Vista PC | SatelliteGuys.US
KwestJones
214
I thought you could just plug it in and play it. For some reason or another it won't play through my pc. I've DL'd PowerDVD and the other they said is supposed to work. The computer recognizes the drive. I can even read the files on it but when I go to play it I get no response or "Unsupported Format." All the web stuff says that Vista is supported...anybody have any tips or ideas?
Requires a HDCP enabled video card/ TV to use through Vista
Just picked up a x1250 based motherboard that supports HDMI out and works fine through Vista this way. (using cyberlink for playback)
Hitachi UnVeils 100GB-200GB Blu-Ray Disc
Hdmi
