I don't have an x-box yet, but was wondering what kind of video connection it supports. I was looking at the manual and it only shows composite video? Does it have Component or DVI connection?
A_Noland said:I don't have an x-box yet, but was wondering what kind of video connection it supports. I was looking at the manual and it only shows composite video? Does it have Component or DVI connection?
This is the out of stock one. It has been replaced by http://home.cfl.rr.com/emp/XBOXHIGHDEF_NEW2.jpgbbqman said:A Noland, try this link and it will tell you what you need.
http://www.xbox.com/en-us/hardware/highdefinitionavpack.htm
Kevinw said:This is the out of stock one. It has been replaced by http://home.cfl.rr.com/emp/XBOXHIGHDEF_NEW2.jpg
http://home.cfl.rr.com/emp/XBOXHIGHDEF_NEW1.jpg
It has been really hard to find the new connector since the old one was discontinued. I finally found one last week at Cicuit City. It was 1 of 2 they had on the rack.ShadowEKU said:man thats weird looking.
If you go into a gamestore like EB they usually have a wall full of the different adapters.
Links are down and I can not find new ones...Neutron said:The majority of Xbox games are in 16:9 format too.
Those two links don't work.
Instead of having a breakout box with seperate component cables, it is now all in one. I just saw them at Fry's tonight while picking up a copy of StarWarsNeutron said:What changed from the MS HD pak?
Limited time offer
