XenForo Update | SatelliteGuys.US
XenForo Update
Not open for further replies.
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,485
28,649
Newington, CT
I will be updating our software in just a few moments to the latest version of XenForo. (Our new forum software.)
The site will be unavailable for a few minutes while the upgrade is completed.
This release fixes a number of bugs and issues that were found since the release of 1.3.3. As this is a maintenance release, the vast majority of the focus was an increase in stability.
Some of the bugs fixed in 1.3.4 include:
  • Fix backwards compatibility/deprecation issue in PHP 5.6
  • Fix logging of password changes in the user change log
  • Attempt to prevent links to proxy.php being inserted into posts in certain cases
  • Ensure that links that do go to proxy.php in posts are considered external
  • Fix situation where search grouping is lost when replaying a search
  • Fix editor menu icon positioning in RTL
  • Fix tooltip positioning over certain avatars in RTL
  • Do not notify users of new posts while drafting a response when the only new posts are by users they ignore
  • Support navigation "counter" bubbles on extra tabs without menus
  • Prevent double HTML encoding in report resolution/rejection alerts
  • Fix issues with IE not always changing the selected image in the lightbox
  • Fix drag and drop upload into the editor when dragging from the download bar in Chrome on Mac
  • Fix IPB import issue relating to corrupt poll choices
  • Ensure that the smilie cache is rebuilt after the display order is updated
  • Ensure that style modification times are updated when style properties in the master style are updated
  • Allow user tagging when the @ symbol is proceeded by a single or double quote
  • Fix Gravatar fallback URL when using an absolute path to an image directory
  • Ensure that debug-only admin navigation entries are not returned by the admin search when they are not viewable
  • Ensure that the search minimum word length option only allows values greater than or equal to 1
See the Resolved Bug Reports forum for further information.
Again this update will be done this morning and the site will be unavailable for a few minutes. :)
All done. :)
This system is SO nice! To update just log into the admin console and click on upgrade. It does the rest. :)
