you tighten the motor bracket nuts so much that you bend the motor bracket and make the motor not level!
When you mount you nice PrimeStar dish on a tripod onto plywood in the driveway and forget to put the cinder blocks on it. Then during a thunder storm it blow into the corn field and while rolling across the stone driveway, rips the arm off the dish. No damage to Invacom LNBF though, still using it.
Limited time offer
