Youtube in HRxx's? | SatelliteGuys.US
Youtube in HRxx's?
DodgerKing
16,776
27
SoCal
I remember reading somewhere that the new software update on the HR2x's are to include Youtube, but I have yet to see any APPS or anything in the menu containing Youtube. Is this rumor true?
You have to do a search, but I forgot exactly what the search terms were.
I already received the latest firmware update on both of my boxes.
Does anyone know how to activate it (if you can do so now)?
Nevermind, when its active, and you use smart search, it'll show up as a youtube hit. Just try searching for a well known youtube video in smart search and see if it pops up.
Thats what I was looking for earlier, just could not remember it exactly.
Now the question I have to check out is do does this work on stock firmware just by searching forthat or do I have to enable Edge Cutter search code first and then the UTUB3ON I have to play with one of my stock boxes later after work.
What Happened to the G4 network
Getting out of region sports networks
