Zinwell 6 x 8 question | SatelliteGuys.US
carlospr43
967
12
US
Does anybody knows if I can use a Zinwell 6 x 8 to feed an additional box to my existing 4 boxes?? Actually I'm feeding 8 lnbs to my 4 openboxes using 4x4 and 1.0 diseqc switch since all my dishes are fixed. I'll be using the 6 x 8 to sustitute one of the 4x4 so I can output to an additional 1.0 diseqc switch (I'm going to be able to feed to 4 more diseqc switches). Will the 6 x 8 work same as a 4 x 4?? Thanks [h=1]Zinwell Direct TV Wb68 Mutiswitch 6x8[/h]
I just realized that in order to get the 8 LNBs I will need (4) 6 x 8 So I can feed all 8 lnbs to the additional Diseqc switch. What will be the most cost effective way to do it???? Is there any switch that I can sustitute in place of one of the Diseqc switch and can do the same job but with 2 outputs?
ku/cband circular/linear
Cars TV Bounce Tv mux at 105W
