DP34 Switch with Bell Expressvu | Page 2 | SatelliteGuys.US
Btw, what receiver(s) are you using? The older ones won't work at all with the DishPro lnb's and switches, unless you use DishProPlus, or use a DP adaptor.
2 x 3100 IRD. (310.10)
So I should by a Twin dish pro plus lnb?
Thank you
The 3100 is dish pro compatible, so you'll be okay with normal dish pro. You're only reason now for dish pro plus, is if you plan to add a dual tuner in the future and want to run only 1 line.
Programming your PVR
SC 8PSK changeover
