Invacom Quad :) | Page 2 | SatelliteGuys.US
Invacom Quad :)
Anyone has this LNB working with a Viewsat Pro?
Anyone has the Invacom Quadpolar successfully working with Viewsat Pro? I am not able to get it working properly; may be because the LNB type selection is not correct in the receiver menu. I would highly appreciate it if you could post the antenna settings you are using for both Circular and Linear polarized satellites.
Thanks!
L.O. for circular satellites is 11250, standard LNBF. L.O. for linear is 10750, standard LNBF.
The problem is the Viewsat Pro does not have specific setting for "Standard LNBF". If you are referring to selecting just 11250 and 10750 under "LNBF Frequency", then it is not working for me; the receiver does not switch 13V/18V for polarity selection with those settings. If I select "Legacy", then it switches voltage, but there is no "Legacy" selection for 10750.
If you have the Viewsat Pro + QPH 031, could you please post the specific "Antenna Settings" you are using?
I don't have a Viewsat, so I don't know how to navigate the menus. Someone here should be able to tell you specifically how to enter these settings on that receiver, I just thought you were looking for the numbers.
Thanks Tron! I got it working. In addition to the LNB Frequency setting, the switch type had to be set to DiSEqC 1.0 Port X for it to work. I was setting the switch to 'none' because the LNB directly connected to the receiver; for some reason it wouldn't work without a switch type selected.
OTA /FTA on sonicview pvr1000
cant get IA5 with a Invacom quad
