I go to ch 499 and still see a searching for sat signal for B-Band signals.
Is this normal still untill they roll out the HD stuff?
also, check channels 480 and 481. they will confirm if your b-band converters are hooked up properly.
480 and 481 confirmed but getting a channel not available message on 499
That is what I get... I guess if you get the slide on ch 498 you are OK?I get a little of everything. 480 gives me a "searching for signal" message. 481 tells me my B-Band is working. 498 earlier gave me the congratulatory message, but not has the "searching for signal" message.
Limited time offer
