it was DNS update Memo, you just gone have to trust me.
Could scan it and post in PDF format ?
I have a 625 DVR. The caller Id feature does not work---long story. Dish has told me that it is a software problem. I wonder if the software update will help my caller ID problem.Do you have a Dish 625 recevier? If so I have some possible good news for you. I am hearing a strong rumor that starting around October 17th Dish Network will begin rolling out a software update that will INCREASE recording space from 100 hours of record time to up to 150 hours of recording time.
I find this news interesting that Dish is giving back some of the space they had reserved for Dish On Demand. I am wondering if we are starting to see the beginning of the phase out of the Dish On Demand satellite delivered to your hard drive service.
I have never prsonally ordered any of the movies from this service, becuse the movies were old, and the movies that I did want to see were OVERPRICED. None of the non new release movies should have ever been priced above $1.99.
There's no encoders in Dish receivers, the raw data stream is recorded on the hard drive.
Have not been following this in detail, but it would seem that the most likely scenerio is that they are extending the main partition which should not require a reformat, and therefore there is no need to lose your existing DVR recordings, or the timers.
If they are changing the format such that they get an effective higher density, then I'd expect to lose timers and DVR recordings. This might also include a different record algorithm allowing higher density. 100 to 150hours is a large increase. But if they are dropping the OnDemand service due to marginal useage, and changing format and condensing algorithm, that might pick up the extra 50hrs.
In any case, I wouldn't think it is necessary for the user to erase anything. It would be done for the user.
Have you read posts here what is partitioning in use on 522/625 disks ?
If not - find it. If yes, then you didn't get it correct.
Ther is no way to Dish preserve recordings.
I would say both models 522/625 will have the changes, it will just less remarkable for 522.
Nope. Only the 625. Once this happens, a defective 522 can no longer be replaced with a 625. It has to be replaced with another 522.
if hdsize > 200 then
. deviceid = '625'
. partitionscheme = 'big'
else
. deviceid = '522'
. partitionscheme = 'normal'
end if
Can My Laptop Hook up to the 625 to save it some how if so how does one do this Please?
Thanks for the Info...
So, Tomorrow I will loose everything I have saved on my DVR..
JUST GREAT!!
Limited time offer
