Hey y'all!
I'm down here in South Texas, which is outside of the official footprint for 129W. I have a D1000.2 and a D500. I can get 129W on the D1000.2, but the "wobble" effect causes my signal to range from 0 to about 65 or so using the newly-calibrated signal meter on my ViP622. I have also used the D500 in the past with better results, but did get some macro-blocking - maybe due to a possibly obstructed view of the satellite at that time.
So I ordered a W-bracket today from Claude at DishStore.net (one of our Gold Sponsors). I plan to test the following two scenarios:
If you have any input or other suggestions, please let me know! My hope is that I can get a usable signal - even when the "wobble" is at its worst. Now that SkyAngel is on its way out and the fish channel is gone, my reasons for choosing 61.5W over 129W are just about gone. By switching to 129W I will pick up my RSN (and perhaps some others
The W-bracket should arrive next week, so testing will probably be the following Saturday unless I need to *cough* call in sick or something.
Red
PS: Yes, I know a larger dish would help with 129W. The point of this exercise is to use existing Dish equipment with little or no additional investment.
- Using a DP Dual LNBF with an I-bracket on the D500, I intend to peak the dish and check signal strength readings with my ViP211.
- Using a DP Dual LNBF in the center position of the W-bracket on the D1000.2, I intend to peak the dish and check signal strength readings with my ViP622.
Red
