No, your drive would have to be empty for this upgrade/reformat to occur. You will not lose anything for now.Thanks for the Info...
So, Tomorrow I will loose everything I have saved on my DVR..
JUST GREAT!!
JUST GREAT!!
o 625 Enhanced SD DVR Recording Capacity for Existing Customers – Beginning with software version L462, certain new and remanufactured model 625 DVRs will have an increased recording capacity of 150 hours as displayed in the "My Recordings" list. Software version L462 is planned to go out to existing-customer 625s between October 16, 2007 and November 8, 2007.
- The increased recording capacity for existing-customer 625s applies if:
? A customer deletes ALL their existing recordings on their 625 and deletes any timers scheduled to occur for the 24-hour period. After this is completed, an existing receiver needs to receive the L462 software version (you may verify if a 625 has received the software between October 16th and November 8th by pressing MENU-6-1-3 on the remote control) and wait for the nightly update to occur (usually around 3:00 AM).
? Existing 625 customers with L462 who do not perform the steps described above will continue to see the original recording capacity (100 hours) and not the 150 hours.
- Additionally, an existing-customer 625 receiver will also have the increased recording capacity if it is newly installed (effective October 17, 2007) or is a replacement receiver (for example, replaced through an RA).
Here is more information on this upgrade.
So, the software is out in the stream now and anyone can get it?
I just did Menu 6-1-3 and I still have version L461.
Now, I don't need to erase all my recordings to get L462 right? So even if I don't delete all my recordings L462 should just download but won't install on my DVR.
I was wondering can I wait till I have the update and then delete all programs and timers at a later date and get the extra 50 hours? Or is it all or nothing at the time the receiver updates?
It's on partial phase, you can see if your receiver # matches the range here:
http://www.satelliteguys.us/1076072-post89.html
Thanks for the info.
I'm assuming I'm supposed to look at the serial numbers here. How do I find the serial number of my receiver? I assume it's listed somewhere when I press Menu 6-1-3?
What if your serial number is not listed for an update? Mine number was 82046234, will it be updated eventually or is just the receivers listed. Just wondering??
Heh heh - you're not in par with your nick.
Search.
Or press Menu button two times.
C'mon, Mulder's too busy chasing aliens to know anything about this DVR/satellite stuff.
I pressed Menu twice and I was just guessing in my last post but I need to know this is the serial number right? Where it says:
Receiver CA ID R00XXXXXXXX-25
Where I put the 8 X's, that's the serial number correct?
Limited time offer
