I have a dish 1000 ant and 622 DVR. I currently get 110, 119, & 129 and would like to get 118 also. Is there anyway I can modify my 1000 setup so I can get 118? Can I add another dish and a dp44 switch or do I have to change to a dish 1000+ antenna?
The 105 SD LNB has the ability swap between circular and linear polarities![]()
If you grasp the "eye" of the 105 LNB, you can actually turn/spin it. By factory default it's set for linear. Just turn it until it comes to a complete stop.
Hello everyone!! I just purchased a Sonicview and a dishnet 1000-hd dish.
I hooked up everything and can't seem to get sonicview to work. What am I doing wrong? I rehooked my coolsat 5000 and I can get reception so I must be doing something wrong. Ant advice would be appreciated cause people are saying how great HD is. I just ran 1 wire cause they say it will hook up to all of them.THANKS
Limited time offer
