Dish 625 DVR Hook Up | SatelliteGuys.US
budhead151
94
3
I'm planing on buying a Panasonic 26" LCD HDTV Model #: PAN TC26LX70. I will be hooking it up to a Dish Network 625 DVR. What is the best way to do this? I also have to hook up a VCR to record NBC with rabbit ears,the rest of my networks come from AAD.
The 625 is a SD Receiver, so it will NOT get any HD Programming at all. I know it has a Coax Output for both Tuner1 and Tuner2. I can't get to that receiver right now (kids are sleeping in that room) so I can't tell you if it has Composite Outputs (Red, Yellow, White) or not, but I don't think it does so you will be stuck with Coax unless you upgrade your receiver.
Geoff
S-Video is your best option with this receiver. I would upgrade to the hd dvr. I had this receiver and upgraded to the vip 722, big picture quality difference, even in sd programming.
I say upgrade to the 622/722 specially right noiw when EVERY customer getes an instant 100 dllrs off any receiver! aaa I wish i had my hdtv :(
and yah s video would be the best option.. but really? why would u want an sd receiver connected to an hdtv without the hd?
Would I need a new Dish with the 722 recceiver? I have a Dish 500 at this time.
If you upgrade to HD you will need a new dish and receiver.
By the way the S-video will give you the best picture quality on the 625. You can also run a optical out for your sound if you have a sound system that will support it.
The Wire in HD for first minute and then SD for the rest?
DPP44 vs. DP34
