Switch Question | SatelliteGuys.US
Switch Question
SarKen
690
3
MA
I have a super dish connected to 119, 110 and 121 with a second dish connected to 61.5. 121 was used for locals, now my locals are only on 61.5. The channels are still on 121 with a message stating that my locals have moved. I could not get the system to pick 61.5 first then 121.
So what I did was remove the 121 feed from my switch from the forth input. Is this ok to do?
Thanks,
Ken
Not sure how the proriority works on 121, but if there is nothing on 121 you want just disconnect that line and run a check switch test.
That is what I did. I just want to make sure that it will not hurt anything.
You're good. Just make sure to do a checkswitch afterwards to clear out guide data for 121 or you will have searching for satellite messages on some channels.
Screen issues with Lost on ABC last night
HD channels in RED not available?
