If nothing else, it confirms that DISH Network has the capacity to add HD channels.As you CORRECTLY observe, this could all just as easily come to nothing.
Actually what the uplink activity and hints and tidbits are doing is creating doubt in those that would have probably already shut off and moved to someone else with more HD.. In other words it's helping plug the hole in the bucket. But sooner or later they are going to have to do more than just uplink things or they are going to be uplinking to an empty audience.
It wasnt the typing that slowed me down, it was the number of phone calls I got as I was typing it.Nice statement Scott - although if it took an hour to type you may need to check out Typing Tutor.
There will be a HD Schedule Channel added today on channel 5794.
I added a link to your mainpage announcement.
Snow? What's that? It was 74 degrees here yesterdayI'm just having fun with him. I'm sure he's busy working. Here in Michigan we are getting hammered with snow and have little work to do.
So are you saying that the "uplink" report is generated from the data stream (downlink) from the satellite? If so, why does Dish send data about all Dish satellites to and from all Dish satellites, rather than uplinking only the map specific to a single satellite?These maps are sometimes called the data stream. A number of folks have figured out how to read this data stream and extract the information from it...
I was under the impression that Digiblur lived somewhere near a Dish uplink center and was actually receiving a sidelobe of an uplink antenna beam.
I was under the impression that Digiblur lived somewhere near a Dish uplink center and was actually receiving a sidelobe of an uplink antenna beam. If that were the case, he could see the data that was uplinked to any satellite from one location. (Of course that doesn't make much sense either since Dish has more than one uplink facility.)
Limited time offer
