My "MyBook 500" failed. I'll never buy another one. It was kinda quirky when it worked- "off" button did not work reliably. Others have reported the same.
Does anyone know if you can move photos from a flash drive on to the internal hard drive of a 722 or 622?
The drive must be at least as large as the internal drive.
It is also important to note that this external storage is not available for live recording, so if you thought you were going to stack up several hundred hours of recording unattended, that's not how it works.
I'm not sure about recording directly to the external HD, though.
The way I found to do that, is to change the sort on the Internal Drive before going to the External Drive.One thing I didn't know for the first month or so that I stumbled upon, was the ability to sort the list on the external drive either by date recorded or alphabetically. I was getting pretty frustrated till I figured that out. With over 200 shows on the external hard drive it was a pain to find what I wanted to watch. Not as good as folders but much better than by date alone.
Is there any way to change the sort while using the External Drive ?
Or do you do it the same way I do ?
Limited time offer
